Discover Device (C# code sample)
Problem this snippet solves:
This C# client code sample uses Enterprise Manager's device inventory to discover a list of devices managed by the referenced Enterprise Manager.
Code :
using System;
using iControl;
 * A class for testing the Management::EM::discover_devices iControl interface.
class ManagementEMDiscoverDevices {
    private static int MIN_ARGS = 3;
    private static int NUM_DEVICE_ARGS = 3;
    private static string USAGE =
"ManagementEMDiscoverDevices    " +
    private static int EM_PORT = 443;
     * The main method.
     * @param args command line arguments
    static void Main(string[] args)
if ((args.Length < MIN_ARGS) ||
        (((args.Length - MIN_ARGS) % NUM_DEVICE_ARGS) != 0)) {
    Console.WriteLine("Usage: " + USAGE);
    Environment.Exit(1);
string emAddress = args[0];
string emUsername = args[1];
string emPassword = args[2];
int numDevices = (args.Length - MIN_ARGS) / NUM_DEVICE_ARGS;
        string[] deviceAddresses = new string[numDevices];
        string[] deviceUsernames = new string[numDevices];
        string[] devicePasswords = new string[numDevices];
        for (int i = 0; i < deviceAddresses.Length; i++) {
            int index = MIN_ARGS + (i * NUM_DEVICE_ARGS);
            deviceAddresses[i] = args[index];
            deviceUsernames[i] = args[index + 1];
            devicePasswords[i] = args[index + 2];
        string taskId = null;
try {
    Interfaces ic = new Interfaces();
    ic.initialize(emAddress, EM_PORT, emUsername, emPassword);
        taskId = ic.ManagementEM.discover_devices(deviceAddresses,
                                                  deviceUsernames,
                                                  devicePasswords);
catch (Exception e) {
    Console.WriteLine("Failed to discover devices: " + e.Message);
Console.WriteLine("Discovery task started with task ID: " + taskId);
    } // Main
} // class ManagementEMDiscoverDevices
Published Mar 07, 2015
