Delete Device (Perl code sample)
Problem this snippet solves:
This Perl client code sample uses Enterprise Manager's device inventory to delete a list of devices managed by the referenced Enterprise Manager.
Code :
#!/usr/bin/perl
use strict;
use SOAP::Lite;
use constant MIN_ARGS => 3;
use constant USAGE => "Management_EM_delete_devices    [] ...";
# Parse command line arguments.
my $num_args = $#ARGV + 1;
if ($num_args < 3) {
    print "Usage: ", USAGE, "\n";
    exit();
my $em_host = $ARGV[0];
my $em_username = $ARGV[1];
my $em_password = $ARGV[2];
my @device_address_list;
for (my $count = 3; $count < $num_args; $count++) {
    push (@device_address_list, $ARGV[$count]);
# Create SOAP proxy.
my $soap = SOAP::Lite
    -> uri('urn:iControl:Management/EM')
-> proxy("https://$em_username:$em_password\@$em_host/iControl/iControlPortal.cgi");
# Delete devices.
my $soap_response = $soap->delete_devices
        SOAP::Data->name(devices => [@device_address_list])
if ( $soap_response->fault )
    print $soap_response->faultcode, " ", $soap_response->faultstring, "\n";
    exit();
print "Device(s) deleted\n";
Published Mar 07, 2015
