Cisco ACE to F5 Conversion - Python 3
Problem this snippet solves:
The goal of this script is to allow for automate migration from Cisco ACE to F5 LTM configuration. It is now a little bit old and have wanted to add to it and update it for a while but other projects have kept me busy so have made it public (Code can be found here https://gitlab.com/stratalabs/ace2f5-py)
This have only tested on 11.x and some 12.x configuration and not all configuration items from a Cisco ACE configuraiton convert but you normally get a warning/alert on items you will need to do manually.
How to use this snippet:
Generate the F5 configuration:
python ace2f5.py -f <ACE configuration input file> [-o <F5 configuration output file>] [-n NOT FULLY IMPLEMENTED (will disable out, i.e. validation to screen only]
If no output file is defined will output to ACE configuration file name plue '.checking'
Can also run and stay in Python CLI using the -i option e.g.
python -i ace2f5.py -f <ACE configuration input file>
After manually checking the output file run the following to generate a clean F5 TMOS configuration file with a
.output
extension. This
.output
is the file to be imported into F5 LTM
python checking-output.py -f <ace2f5.py checking file>
Tested this on version:
11.6
Updated Jun 05, 2023
Version 2.0
