C# Polling Default Pool Connections
Problem this snippet solves:
This C# application will display the current connections for all of the default pools. There was found to be too much overhead when sending in the list of all pools, some of which were empty so this app strips out the virtual servers with non-defined default pools and batches up requests for statistics.
Code :
using System;
using System.Collections.Generic;
using System.Text;
using iControl;
using System.Diagnostics;
namespace PRVD.iControl.GetAllPoolCurrentConnections
class Program
static void Main(string[] args)
if (args.Length < 3 || string.IsNullOrEmpty(args[0]) ||
string.IsNullOrEmpty(args[1]) || string.IsNullOrEmpty(args[2]))
Console.WriteLine(
"Usage: f5GetAllPoolCurrentConnections [username] [password] [hostname or ip address] optional [partition]");
return;
string user = args[0];
string pass = args[1];
string ipAddress = args[2];
string partition = "";
if (args.Length > 3 && !string.IsNullOrEmpty(args[3]))
partition = args[3];
Interfaces m_interfaces = new Interfaces();
m_interfaces.initialize(ipAddress, user, pass);
//Check if inialized
if (!m_interfaces.initialized)
Environment.Exit(Environment.ExitCode);
//Get the partition list to drop into PROD
bool partitionFound = false;
ManagementPartitionAuthZPartition[] partitionList = m_interfaces.ManagementPartition.get_partition_list();
for (int i = 0; i < partitionList.Length; i++)
Console.WriteLine("Partition found: {0}", partitionList[ i ].partition_name);
if (partitionList[ i ].partition_name == partition)
m_interfaces.ManagementPartition.set_active_partition(partitionList[ i ].partition_name);
partitionFound = true;
if (!partitionFound)
Console.WriteLine("The partition '{0}' specified was not found.", partition);
return;
//Get all virtual servers
string[] localVirtualServers = m_interfaces.LocalLBVirtualServer.get_list();
//PrintInfo(localVirtualServers);
//Get all the active default pools
string[] localDefaultPools = m_interfaces.LocalLBVirtualServer.get_default_pool_name(localVirtualServers);
//PrintInfo(localDefaultPools);
//Get the pool stats
LocalLBPoolPoolStatistics poolStats = new LocalLBPoolPoolStatistics();
//Get the pool stat entries
LocalLBPoolPoolStatisticEntry[] poolStatEntries;
//Load the localDefaultPools into a List object to prune and perform batch get_statistics with
List localDefaultPoolsList = RemoveNoNamePools(localDefaultPools);
string[] poolBatch;
int batchCount = 1;
Stopwatch timer = new Stopwatch();
timer.Start();
//Break the statistics rquests into batchs of XX
while(localDefaultPoolsList.Count > 0)
if(localDefaultPoolsList.Count >= 10)
poolBatch = localDefaultPoolsList.GetRange(localDefaultPoolsList.Count - 10, 10).ToArray();
localDefaultPoolsList.RemoveRange(localDefaultPoolsList.Count - 10, 10);
poolStats = m_interfaces.LocalLBPool.get_statistics(poolBatch);
poolStatEntries = poolStats.statistics;
PrintStatistics(poolStatEntries);
else
poolBatch = localDefaultPoolsList.ToArray();
localDefaultPoolsList.Clear();
//Console.WriteLine("Batch {0} time elapsed: {1}", batchCount.ToString(), timer.Elapsed.ToString());
batchCount++;
Console.WriteLine("Total time elapsed: {1}", batchCount.ToString(), timer.Elapsed.ToString());
timer.Stop();
private static List RemoveNoNamePools(string[] localDefaultPools)
List localDefaultPoolsList = new List();
foreach (string poolName in localDefaultPools)
if (poolName != "")
localDefaultPoolsList.Add(poolName);
return localDefaultPoolsList;
public static void PrintInfo(string[] info)
for (int i = 0; i > info.Length; i++)
Console.WriteLine(info[ i ].ToString());
public static void PrintStatistics(LocalLBPoolPoolStatisticEntry[] poolStatEntries)
//Loop through each pool and print out the server side current connection stats
for (int i = 0; i < poolStatEntries.Length; i++)
CommonStatistic[] commonStats = poolStatEntries[ i ].statistics;
for (int x = 0; x < commonStats.Length; x++)
if (commonStats[x].type == CommonStatisticType.STATISTIC_SERVER_SIDE_CURRENT_CONNECTIONS &&
poolStatEntries[ i ].pool_name != "")
Console.WriteLine("Pool name: {0} Current connections: {1}", poolStatEntries[ i ].pool_name, commonStats[x].value.low.ToString());
} Published Mar 07, 2015
Version 1.0Steffen_Beach_8
Joined October 30, 2009
Steffen_Beach_8
1 Comment
- Kochav
Thank you for this snippet but when I tried to run this code, and it get to the of getting the statistics "LocalLBPool.get_statistics(poolBatch)" it break and raise an exception "System.InvalidOperationException was unhandled" HResult=-2146233079 Message=There is an error in XML document (232, 79). Source=System.Xml do you know why?
