C# Making Async Calls using the iControlAssembly
Problem this snippet solves:
This C# example application shows three different ways to make iControl calls Asynchronously using the An iControlAssembly library. Each way serves a slightly different purpose depending on the needs of the application.
Code :
using System;
using System.Collections.Generic;
using System.Text;
using iControl;
using System.Diagnostics;
using System.Threading;
namespace iControlAssemblyAsyncExample
    class AsyncExample
        private static Thread mainThread;
        static void Main(string[] args)
            Stopwatch sw = null;
            Interfaces m_Interfaces = null;
            IAsyncResult ar = null;
            string[] poolList = null;
            // Synchronously connect to the BigIP Appliance
            Console.WriteLine("Establishing connection to Appliance.");
            sw = Stopwatch.StartNew();
            m_Interfaces = new Interfaces("hostname", "username", "password");
            Console.WriteLine("Connection completed in {0} ms\n", sw.ElapsedMilliseconds);
            // Synchronously Retrieve the Pool List
            Console.WriteLine("Beginning syncronous Pool list retrieval.");
            poolList = m_Interfaces.LocalLBPool.get_list();
            Console.WriteLine("Syncronous retrieval completed in {0} ms\n", sw.ElapsedMilliseconds);
            // Asynchronously retrieve the Pool List, do something and then wait
            // for the Async call to complete.
            Console.WriteLine("Beginning async retrieval with wait.");
            ar = m_Interfaces.LocalLBPool.Beginget_list(null, null);
            // Do some work, which may or may not take longer than
            // the Async call to execute.
            Console.WriteLine("Done some work after {0} ms.  Now waiting.",sw.ElapsedMilliseconds);
            ar.AsyncWaitHandle.WaitOne();   // Wait indefinitely for the Async Call to complete
            ar.AsyncWaitHandle.Close();
            poolList = m_Interfaces.LocalLBPool.Endget_list(ar);
            Console.WriteLine("Asyncronous retrieval completed in {0} ms\n", sw.ElapsedMilliseconds);
            // Asynchronously Retrieve the Pool List while doing something indefinitely.
            Console.Write("Beginning inline async retrieval");
            while (ar.IsCompleted == false)
                Console.Write("."); // Continually to something until the Async
                Thread.Sleep(15);   // call has completed.
            Console.WriteLine("\nAsyncronous retrieval completed in {0} ms\n", sw.ElapsedMilliseconds);
            // Asynchronously Retrieve the Pool List with a Callback
            AsyncCallback myCallBackRoutine = new AsyncCallback(MyAsyncCallback);
            mainThread = Thread.CurrentThread;
            Console.WriteLine("Beginning Callback Async retrieval");
            ar = m_Interfaces.LocalLBPool.Beginget_list(myCallBackRoutine, m_Interfaces);
            try
                while (true)
                    Console.Write("."); // Do something useful while we
                    Thread.Sleep(15);   // wait for the Callback to complete.
            catch (ThreadInterruptedException)
                Console.WriteLine("\nAsyncronous Callback retrieval completed in {0} ms\n", sw.ElapsedMilliseconds);
            Console.WriteLine("Press ANY key to exit.");
            Console.ReadKey();
        private static void MyAsyncCallback(IAsyncResult ar)
            Interfaces m_Interfaces = (Interfaces)ar.AsyncState;
            string[] poolList = m_Interfaces.LocalLBPool.Endget_list(ar);
            int c = 0;
            while (c < 7)
                Console.Write("X"); // Do something useful while the main
                Thread.Sleep(15);   // thread is doing what it needs to
                c++;
            mainThread.Interrupt();
Published Mar 07, 2015
1 Comment
