mulhollandm_648
Oct 21, 2015XenApp iapp using APM and LTM
folks
I'm looking at implementing citrix xenapp using storefront over an apm and ltm
my plan is to terminate the user's ssl on the apm using the latest iapp and then use a single pool member (the ltm)
i'll use the ltm for load balancing
I was wondering if anyone has implemented this and if so are there any issues to look out for?
thanks folks
