X-FORWARDED-FOR AND ERASING SNAT IP FROM APACACHE LOGS
I am using x-forwarded-for and the web server admins would like to not see the snat ip in the logs. Currently I see both the client and snat ip. The client being 208.97.218.10 and snat 10.128.254.13. Can something be done within the x4 profile? - "Request Header Erase"? I
Apache logs 208.97.218.10, 10.128.254.13 - - [08/Jul/2014:10:06:42 -0500] "GET /XXXXXX/ HTTP/1.1" 200 2313 "-" "Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.11 (KHTML, like Gecko) Chrome/23.0.1271.95 Safari/537.11"
208.97.218.10, 10.128.254.13 - - [08/Jul/2014:10:06:42 -0500] "GET /XXXXXX HTTP/1.1" 304 - "XXXXXX" "Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.11 (KHTML, like Gecko) Chrome/23.0.1271.95 Safari/537.11"
Apparently the below irule also did not work to clear the double entries:
when HTTP_REQUEST { if {[HTTP::header exists X-Forwarded-For]}{ HTTP::header replace X-Forwarded-For "[HTTP::header X-Forwarded-For], [IP::remote_addr]" } else { HTTP::header insert X-Forwarded-For [IP::remote_addr] } } }
- Kevin_Stewart
Employee
The XFF header is a layer 7 object, while the SNAT address is a layer 4 value. You cannot use an iRule to change the SNAT address without altering routing and potentially defeating the reason you're using SNAT in the first place.
I would suggest tailoring the Apache log config to ignore the source address, the %h LogFormat value, and perhaps replacing it with the XFF header value \"%{X-Forwarded-For}i\"
- ofilipe_68719
The admin tried the %h and mentioned there was a comma seperated value issue. The strange thing is I do not see this on other device vips:
146.180.106.231 - - [09/Jul/2014:14:04:45 -0500] "POST /XXXXXX HTTP/1.1" 200 1177 "XXXXXX" "Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; WOW64; Trident/5.0)"
66.150.110.71 - - [09/Jul/2014:14:04:55 -0500] "POST /XXXXXX HTTP/1.1" 200 25 "xxxxxxxxxxxxxxxxxx" "Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; WOW64; Trident/5.0)"
- Kevin_Stewart
Employee
So what does it look like if you do something like this?
LogFormat "\"%{X-Forwarded-For}i\" %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined LogFormat ""%{X-Forwarded-For}i\" %l %u %t \"%r\" %>s %b" common - Gabriel_Castro_
Hi folks,
I am facing the same problem, where the XFF is working but I still receiving the selfip sometimes on the APACHE's log.
Would you help me out with this?
Thank you, Gabriel Castro
- Kevin_Stewart
Employee
You're basically getting two different IP addresses in different data streams. One is coming from an HTTP header (layer 7) and the other at TCP/IP layer 3. If you don't want the layer 3 address, then you need to configure your Apache logs to ignore this value.
- JRahm
Admin
if going through multiple proxies, the XFF will end up as a list instead of single IP. You'd need to split the list and select one of them (like NOT the self) and then do a header replace on XFF.
Related Info:
