mrpre_179829
Dec 11, 2014Why couldn't i use 'TLS1.1' or 'TLS1.2' to build connection between browser and virtual service ?
"BIGIP-11.3.0.39.0-scsi.vmx" is running on Vmware Workstation9.0 but i can only use tls1.0 to access the virtual server.I don't know why the virtual server always replys tls1.0.
- Kevin_K_51432Historic F5 Account
Greetings Mrpre, My guess would be for optimal speed. You could disable TLS1.0 in the SSL profile under the options list section. Also, you could add DEFAULT:!TLSv1 to the ciphers option.
https://support.f5.com/kb/en-us/solutions/public/13000/100/sol13171.html
Hope this is helpful, Kevin
