Where is the best centralized documentation on iRule changes between versions?
Hi. I'm working on upgrading some BigIPs from 10.2.4 to 11.6.1. I know there have been a number of changes to iRules, such as removal of the HTTP::class command, deprecation of matchclass, $::data_group syntax going from deprecated in v10 to sending resets to clients in v11, etc. But I'm not convinced that I know of all the changes I should be looking for. Does anyone know where good, centralized documentation is stored on iRule changes that one should be aware of when upgrading?
Hello,
The best doc can be found here (https://devcentral.f5.com/wiki/irules.homepage.ashx)
You will find description on each command, event, etc and also all changes, deprecation are documented.
Otherwise, you can check each release note for a behavior change
