What is relation between Sync and "enable HA"?
Hi The following are Sync and enable HA. Do you think two of them have any relation? No natter if the HA is enable or disabled, we could not find any effect on Sync. Do you think so? Thank you
Device Management >>>>> Overview >>>>> Choose "Self" >>>>>> choose "Sync Device to Group" >>>>> click Sync
System >>>>> High Availability >>>>> HA Group >>>>> check Enable box >>>>> click "Update"
- Vijay_E
Cirrus
Sync - Synchronizes configuration in the HA group.
Enable HA - Creates HA Group.
This means, there is a device available to take over if one of the device fails. However, the new device that takes over may not have the same configuration as the failed device, if sync isn't enabled.
Above info is a high-level overview.
