gossett_151899
Apr 25, 2014what is a tmsh command to test connectivity between two ipsec gateways
I've gotten IPsec set up between the BIGIP and a cisco but can't understand how to check general connectivity back and forth. Thanks guys
- What_Lies_Bene1
You're best bet would be to do a ping between two hosts at either end of the VPN (obviously two that are allowed to communicate over it). Of course, if you didn't permit ping this won't work. In that case, perhaps use telnet or ncat on the relevant port.
