hankycheng_3513
Jan 08, 2013Weblog export problem
Hi All
I have some question about weblog export.
I have set Http Virtual Server into F5 ( BIG-IP 11.2.1 Build 807.0 Hotfix HF1) , then how to export web log using W3C format?
- nitass
Employee
is this usable?
Formatted Logging For W3c
https://devcentral.f5.com/wiki/irules.FormattedLoggingForW3c.ashx - hankycheng_3513
Tks nitass, I will go to reivew.
One more question, how to check the object if I enable optimized-caching? And it will be logging if object caching?
Tks! - nitass
Employee
how to check the object if I enable optimized-caching?is this what you are asking?
sol13255: Displaying and deleting RAM Cache entries from the command line (11.x)
http://support.f5.com/kb/en-us/solutions/public/13000/200/sol13255.html
And it will be logging if object caching? HTTP_RESPONSE is not triggered when object is retrieved from cache. HTTP_RESPONSE_RELEASE is triggered. however, some HTTP:: command is not available such as HTTP::status.
HTTP_RESPONSE_RELEASE Wiki
https://devcentral.f5.com/wiki/iRules.HTTP-RESPONSE-RELEASE.ashx - hankycheng_3513
Tks nitass, Displaying and deleting RAM Cache is useful for me.
On HTTP_RESPONSE_RELEASE , it cannot be trigger HTTP action like get or HTTP return code ... etc? - nitass
Employee
On HTTP_RESPONSE_RELEASE , it cannot be trigger HTTP action like get or HTTP return code ... etc?http method (e.g. GET) is saved since HTTP_REQUEST event. HTTP::status command is not valid in HTTP_RESPONSE_RELEASE event.
HTTP::status Wiki
https://devcentral.f5.com/wiki/irules.http__status.ashx
anyway, to have status code in log, you may use 2 virtual servers and call 2nd virtual server from the 1st one.
e.g.frontend virtual server (using virtual command and log) root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar-frontend ltm virtual bar-frontend { destination 172.28.20.14:80 ip-protocol tcp mask 255.255.255.255 profiles { http { } tcp { } } rules { myrule-frontend } source 0.0.0.0/0 source-address-translation { type automap } vlans-disabled } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule-frontend ltm rule myrule-frontend { when HTTP_REQUEST { Save Request Side Information set http_request "\"[HTTP::method] [HTTP::uri] HTTP/[HTTP::version]\"" set http_request_time [clock clicks -milliseconds] set http_user_agent "\"[HTTP::header User-Agent]]\"" set http_host [HTTP::host] set http_username [HTTP::username] set client_ip [IP::remote_addr] set client_port [TCP::remote_port] set http_request_uri [HTTP::uri] set referer [HTTP::header value referer] virtual bar-backend log local0. "--" } when HTTP_RESPONSE { set response_time [expr [clock clicks -milliseconds] - $http_request_time] set virtual [virtual] set content_length 0 if { [HTTP::header exists "Content-Length"] } { set content_length [HTTP::header "Content-Length"] } set lb_server "[LB::server addr]:[LB::server port]" if { [string compare "$lb_server" ""] == 0 } { set lb_server "" } set status_code [HTTP::status] set content_type [HTTP::header "Content-type"] set log_msg "" append log_msg "virtual=$virtual " append log_msg "client_ip=$client_ip " append log_msg "client_port=$client_port " append log_msg "lb_server=$lb_server " append log_msg "host=$http_host " append log_msg "username=$http_username " append log_msg "$http_request_uri " append log_msg "request=$http_request " append log_msg "server_status=$status_code " append log_msg "content_type=$content_type " append log_msg "content_length=$content_length " append log_msg "resp_time=$response_time " append log_msg "user_agent=$http_user_agent " append log_msg "referer=$referer" log local0. $log_msg log local0. "--" log local0. $log_msg } } backend virtual server (using optimized-caching profile) root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar-backend ltm virtual bar-backend { destination 1.1.1.1:80 ip-protocol tcp mask 255.255.255.255 pool foo profiles { http { } { } tcp { } } rules { myrule-backend } source 0.0.0.0/0 source-address-translation { type automap } vlans-disabled } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule-backend ltm rule myrule-backend { when HTTP_REQUEST { log local0. "--" } when HTTP_RESPONSE { log local0. "--" } } 1st request (object is not cached yet) [root@ve11a:Active:Changes Pending] config tail -f /var/log/ltm Jan 10 13:12:15 ve11a info tmm1[11170]: Rule /Common/myrule-frontend : -- Jan 10 13:12:15 ve11a info tmm1[11170]: Rule /Common/myrule-backend : -- Jan 10 13:12:15 ve11a info tmm1[11170]: Rule /Common/myrule-backend : -- Jan 10 13:12:15 ve11a info tmm1[11170]: Rule /Common/myrule-frontend : -- Jan 10 13:12:15 ve11a info tmm1[11170]: Rule /Common/myrule-frontend : virtual=/Common/bar-frontend client_ip=172.28.19.251 client_port=34313 lb_server=1.1.1.1:80 host=172.28.20.14 username= request="GET / HTTP/1.1" server_status=200 content_length=89 resp_time=6 user_agent="curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5]" referer= object is cached [root@ve11a:Active:Changes Pending] config tmsh show ltm profile ramcache optimized-caching Ltm::Ramcaches /Common/optimized-caching Host: 172.28.20.14 URI : / -------------------------------------- Source Slot/TMM 1/0 Owner Slot/TMM 1/1 Rank 1 Size (bytes) 353 Hits 0 Received 2013-01-10 05:12:15 Last Sent 2013-01-10 05:12:15 Expires 2013-01-11 05:43:58 Vary Type none Vary Count 1 Vary User Agent none Vary Encoding none Total records returned: 1 2nd request you can see HTTP_RESPONSE in myrule-backend is not executed because object is retrieved from cache [root@ve11a:Active:Changes Pending] config tail -f /var/log/ltm Jan 10 13:12:40 ve11a info tmm[11170]: Rule /Common/myrule-frontend : -- Jan 10 13:12:40 ve11a info tmm[11170]: Rule /Common/myrule-backend : -- Jan 10 13:12:40 ve11a info tmm[11170]: Rule /Common/myrule-frontend : -- Jan 10 13:12:40 ve11a info tmm[11170]: Rule /Common/myrule-frontend : virtual=/Common/bar-frontend client_ip=172.28.19.251 client_port=34314 lb_server=1.1.1.1:80 host=172.28.20.14 username= request="GET / HTTP/1.1" server_status=200 content_length=89 resp_time=0 user_agent="curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5]" referer=
