Web page incomplete after redirection
I need to publish internal.mydomain.com/aaa/bbb as external.mydomain.com
I have created a policy with two rules:
--- FIRST RULE ---
HTTP host is external.mydomain.com
HTTP URI path is /
then
redirect to location external.mydomain.com/aaa/bbb
--- SECOND RULE ---
then
forward to pool mypool
Initially it seems to work properly, the Internet user is taken correctly to portal login page at internal.mydomain.com/aaa/bbb. But after login, the main portal page content is not loaded, just some header parts and main menu.
If I remove the FIRST RULE from policy, obviously user is not redirected,and needs manually go to the correct location(/aaa/bbb), but then portal loads without issues.
Unfortunately I don't have access to that site and don't know it's structure. What I'm doing wrong?
thanks
- Vijay_E
Cirrus
I don't think you are doing anything wrong when the page loads. I would say check the server. Did you try using different browsers ?
