we have created a VLAN in F5 VCMP but its not taking effect. Not showing in VLAN allowed list
Hi we recently created vlan
f5ltm(cfg-sync In Sync)(Active)(/Common)(tmos) list net vlan net vlan xxx { description xxx if-index 144 tag 1011 }
net self yyy{ address x.x.x.x/28 allow-service { default } floating enabled traffic-group traffic-group-1 unit 1 vlan xxx }
anx0110lb420-dmz)(cfg-sync In Sync)(Active)(/Common)(tmos) list net self net self DIGI-MNP-WEB-LB1 { address x.x.x.x/28 allow-service { default } traffic-group traffic-group-local-only vlan xxx }
acn-asami@(anx0110lb420-dmz)(cfg-sync In Sync)(Active)(/Common)(tmos) show net vlan-allowed
Vlan-Allowed
Name ID
abc-vlan 1018 cdf-vlan 1015
in the allowed list newy created vlan tag 1011 is not showing.
- purna_256577
Vlan-Allowed Name ID
xxxx 1018 yyyy 1013
- arpydays
did you use the create command in tmsh or via the GUI? If tmsh can you post what was entered to create the vlan.
