donmunyak_10415's avatar
donmunyak_10415
Aug 08, 2008
Virtual 'Offline' reporting from LTM console.
re: Virtual 'Offline' reporting from LTM console.
I am trying to compile a list of Virtuals where the status = Offline.
Basically house cleaning on a given LTM
I cannot find a reference or attribute for "VIRTUAL status = Available | Unavailable | Offline | Unknown"
b virtual virtual_name show ....shows everything about a 'specific' virtual.
b virtual all |grep -i "inactive,down" .... shows all inactive down pools
I need a one line command to output all Virtuals which have inactive,down pools OR status Offline... which ever would be easiest.
I hoping to get an answer to my question .. or a better solution
  • i think the easiet will be a snmpwalk and then grep or something or use snmp + perl or something ..
  • To see offline virtuals:
    From tmsh: show ltm virtual | grep offline -B 3 | grep Ltm
    From bash: (so you can use the q switch and output the whole list at once, pipe to a file if desired) tmsh -q show ltm virtual | grep offline -B 3 | grep Ltm
    To see virtuals with 0 connections:
    From tmsh: show ltm virtual | grep 'Current Connections 0' -B 17 | grep 'Ltm::Virtual'
    From bash: tmsh -q show ltm virtual | grep 'Current Connections 0' -B 17 | grep 'Ltm::Virtual'
    Used on 11.6.3
