VCMP, VServer and External LAN
Actually I have just one LACP with some vlans,then some of this VLANS go to some vCMP guests.
I want to change the behaviour and add a Transport L3 between F5 and switch.
Where I must add the L3 interface on F5? I need to pass the L3 to each Guest? It can be on vCMP host?
I expect you can understand the scenario...
Regards!!
you don't configure any IPs except mgmt on the vcmp host in general. so it would be on the vcmp guest. but there i doubt you want them all in the same network (not even sure if that is allowed at all), so one transport network per vcmp guest i would say.
