amolari
Oct 22, 2012v11.2 sharepoint iApp issue with external monitor
hi
I've created an external monitor called "http-ntlm" and it cannot be selected in the drop-down menu, monitor section of the iApp. The template calls the function "tmsh::run_proc f5.app_utils:get_ltm_monitors_filter http" but this searches only in the built-in monitors folder, not the external ones. Anyone has found a workaround (still allowing selection) to this issue?
Alex
- Mitra_Kelly_625Historic F5 AccountHi,
The new external monitor that you created will be of type "external" and the template code is only looking for monitors of type "http". I believe that if you make a copy of the template and change the "tmsh::run_proc f5.app_utils:get_ltm_monitors_filter http" line to instead say "tmsh::run_proc f5.app_utils:get_ltm_monitors_filter http external" then that drop-down should contain the list of http monitors plus the list of external monitors.
If that doesn't work for you, let me know and I'll look into it further.
Mitra - amolari
hi Mitra,
thanks! It works.
Regards
Alex - Mitra_Kelly_625Historic F5 AccountJust as an update, we will be providing access to external monitors in our iApp templates beginning in version 11.4.0
