Kevin_Nail's avatar
Kevin_Nail
Dec 19, 2008
using XFF and https
Was wondering when using the X-Forwarded-For header on https if I need to terminate the entire SSL session on the LTM via a client-ssl profile or can I just use store a copy of the key decrypt the traffic?
Any thoughs are appreciated.
  • hoolio's avatar
    hoolio
    If you want to inspect or modify the HTTP headers or data, you'd need to decrypt the traffic on LTM using the SSL key configured in a client SSL profile. If the LTM to server connection needs to be encrypted, you could use a server SSL profile to re-encrypt the traffic.
    Aaron
