Akshay_Chawade_'s avatar
Akshay_Chawade_
19 years ago
Using RasDial to invoke Firepass connection
My application used RasDial() to connect to various servers. The connections to server is defined in Windows Dial-up Networking. Is there any way I can add Firepass too as a Dial-up connection. That way, I need not change my application to make a secure connection.
Thanks and Warm Regards,
Akshay
  • you might want to try installing the standalone dialer (device management>client downloads). It has Windows Logon (GINA) integration, you can have a 'connect to' entry from Windows Start and a dialup entry in Control Panel>Network Connections along with a standalone client to connect without a browser. You can even use/enforce pre-logon sequences with it. hope that helps.
    ps
