using Range of ports on a virtual server with/without using iRules
Dears , i'm currently trying to implement a HA LTM/ASM appliances on a Web application server that serves around 27 customers , The Web application server has around 20 services each service will use a specific port , each customer will use a range of ports as follows: Customer A : 5000-5019 , Customer B : 5020-5039 ..... etc. "THE SAME IP ADDRESS WILL BE USED FOR AL CUSTOMERS".
for management and future needs , each customer should have his VS but I'm not sure if we can create 27 VS and configure an iRule to specify the range or i have to create 27x20 VS which will be an administrative nightmare.
any advice will be much appreciated.
Best Regards, Ahmad.
- Kevin_Stewart
Employee
You can create a VIP that listens on an IP and any port (wildcard), but you can't create multiple VIPs with the same destination IP and wildcard port. You have a few options though:
Create a single VIP with destination IP and wildcard port and use an iRule to pool to resources based on requested port. You could also optionally give each customer a different DNS name to the VIP and load balance based on that.
Create a separate IP and wildcard port VIP for each customer (a different IP address for each). You can then optionally limit access based on the defined ports.
- Mike_Maher
What version of code are you running? If you are 11.4.x you may have some options with Local Traffic policies - Ahmad_Mohaidat_
it is 11.5
