Using an iRule to route SQL traffic
Here is our setup. We have a SharePoint farm, four BISM (SSAS) SQL Servers and 4 ETL Servers, all 2008 R2 Servers. We are trying to setup 2 "pods" each with 2 BISM/2ETL Servers.
THe BISM servers go through an F5. We need to an have iRule route traffic, so we can segregate BISM traffic to the 'pods" according to a certain value, maybe a token, whatever will work. The problem is that between the SP Farm and BISM Server there is TCP (SQL) traffic.
Questions: 1. How can tell what the TCP traffic contains from the SP Farm to the BISM Servers? I have tried TCP::collect and not sure where to look to see the traffic. 2. I need to use a variable of from the packets to compare to a data group, is that possible? 3. Any help with writting an iRule would be greatly appreciated.
Thank you!
- Kevin_Stewart
Employee
The new MS SQL profile in 11.5 allows you to balance across SQL pools based on command (read or write) and user (from a defined list). Beyond this there's no built-in SQL parsing function, so you'd necessarily have to build a pretty complex binary-based iRule, which I wouldn't recommend. That said, if 1) you can define a value early on in the SQL data, and b) that data is in every request (or at least 1 per TCP session), then there's still a chance you could read this and do something useful.
- nitass
Employee
as Kevin mentioned, TDS command and event are introduced in 11.5.0.
TDS
https://devcentral.f5.com/wiki/iRules.TDS.ashx - Dmitry_Sherman
For some reason this feature is missing in both 11.5 and 11.5.1 LTM (VE) GUI, but found it in tmsh, any ideas why it was removed?
- nitass
Employee
it is fixed in 11.6.0.
ID434414 - MS SQL Proxy Profile is visible in al Virtual Server GUI configuration screens
- Dmitry_Sherman
thanks! Is it considered stable? When can I get the 11.6 release?
- nitass_89166
Noctilucent
i understand it is not experimental.
it is not determined yet.
- James_124570
Now that 11.6 version is released. Is there any documentation on how to setup/configure MS SQL profiles?
- nitass
Employee
- James_124570
