Use of switch -glob statement to switch the traffic in place of if or elseif statement in Irule
Hi Sir,
Wanted to make efficient use of switch -glob statement to switch the traffic in place of if or elseif statement: Kindly guide how the Irule looks like.
when HTTP_REQUEST { log local0. "Uri is [HTTP::uri]" if { [HTTP::uri] equals "/" } { HTTP::redirect "http://[HTTP::host]/SEUILibrary/controller/Lenovo:Enter" log local0. "redirecting to http://www.lenovo.com/us/en" return } elseif {[HTTP::uri] eq "/console"} { HTTP::redirect "http://canadauat.leni2.com" return } elseif {[HTTP::uri] contains "/login.workflow:Enter"} { HTTP::redirect "http://canadauat.leni2.com" return } elseif {[HTTP::uri] contains ":SiteStatus"} { HTTP::redirect "http://canadauat.leni2.com" return } elseif {[HTTP::uri] contains "/seapibroker"} { HTTP::redirect "http://canadauat.leni2.com" return } elseif {[HTTP::uri] contains "/Author"} { HTTP::redirect "http://canadauat.leni2.com" return } }
Kindly guide.
Regards
- OTS02
Cirrus
Here is a starting point. I removed the "return"s, so you will have to put them back.
when HTTP_REQUEST { switch -glob [HTTP::uri] { "/" { HTTP::redirect "http://[HTTP::host]/SEUILibrary/controller/Lenovo:Enter" log local0. "redirecting to http://www.lenovo.com/us/en" return } "/console" { HTTP::redirect "http://canadauat.leni2.com" } "/login.workflow:Enter" { HTTP::redirect "http://canadauat.leni2.com" } ":SiteStatus" { HTTP::redirect "http://canadauat.leni2.com" } "/seapibroker" { HTTP::redirect "http://canadauat.leni2.com" } "/Author" { HTTP::redirect "http://canadauat.leni2.com" } default { HTTP::redirect "http://somewhere.anywhere.com/last/resort.aspx" } } }
If this is a website that you are concerned about search-engine rankings, you may consider using 301 redirects: HTTP::respond 301 Location "http://somewhere.anywhere.com/last/resort.aspx" Also if you did - switch -glob [string tolower [HTTP::uri]], then if somebody did not type in the case correctly, it would still work (of course, you would have to make all of your match-cases lower case. Hope this helps.
- Parveez_70209
sorry I am failing to understand the Irule. Can you put in some good format.
- nathe
Cirrocumulus
I've amended slightly, including string tolower and removing some of the lines. hope this is what you're after.
when HTTP_REQUEST { switch -glob [string tolower [HTTP::uri]] { "/" { HTTP::redirect "http://[HTTP::host]/SEUILibrary/controller/Lenovo:Enter" log local0. "redirecting to http://www.lenovo.com/us/en" } "/console" - "*/login.workflow:enter*" - "*:sitestatus*" - "*/seapibroker*" - "*/author" { HTTP::redirect "http://canadauat.leni2.com" } default { HTTP::redirect "http://somewhere.anywhere.com/last/resort.aspx" } } }Hope this helps.
N
