URI Based Filtering using ASM Module ?
Hello,
I am doing replace based LTM Policy as below , below 3 line is path for 3 different company and want to control each company can access to their respective URL not the other ones. Like if Company1 need to access 1st URL they will access it but want to restrict remaining 2 URI for Company 1.
I have ASM Module Provisioned , can I use ASM Policy to achieve this ? All these Companies will have different IPs as SOURCE.
if traffic comes to https://test.test.com:443/Test/Company1/ replace to /Path/Company1/ path of Pool1
if traffic comes to https://test.test.com:443/Test/Company2/ replace to /Path/Company2/ path of Pool1
This is a typical use case for local traffic policy. I wonder why you want to replace that?
- JRahm
Admin
you can use the source IPs to differentiate what paths are accessible and can incorporate that directly into your policy, either by address list in the policies or via datagroups. Here's the address list version:
ltm policy access_by_src_ip { controls { forwarding } last-modified 2021-12-22:15:50:07 requires { http tcp } rules { app1 { actions { 0 { forward select pool pool1 } } conditions { 0 { tcp client-accepted address matches values { 1.1.1.1 } } } } app2 { actions { 0 { forward select pool pool2 } } conditions { 0 { tcp client-accepted address matches values { 2.2.2.2 } } } ordinal 1 } app3 { actions { 0 { forward select pool pool3 } } conditions { 0 { tcp client-accepted address matches values { 3.3.3.3 } } } ordinal 2 } } status published strategy first-match }
