Urgent persistance connection issue
We are running BIGIP version 10.2.4 with LTM.We are load balancing our ISP connections using BIGIP recently some users are complaining about the connection session issues.
Problem
If a users is trying to connect to https website this will open session and goes to our ISP 1 and after some time the same user try to click on some other link on the same website it goes to ISP 2 so for the same website vendors are seeing two different IP's because of this users are not able to complete any transactions.
Can you please let me know where i can chek the issue in BIGIP and how to fix this issue.
Thanks for your help
- hoolio
Do you have destination address persistence enabled on the outbound virtual server?
https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm_configuration_guide_10_1/ltm_persist_profiles.html
Aaron - gg234_32466
Default persistence profile configured as none so no destination address persistence enabled
