Shishir_84445
Feb 14, 2011Urgent Help! Please! TACACS ROLES
Hello,
I have setup TACACS on F5 but having one problem. I have defined "Admin" and "Guest" groups on F5, so whenever I logged into F5, I get "bigpipe shell" prompt. How I can get full prompt access? I want to get prompt like when I use "Admin" account. Which role should I define from following under each group?
0- Administrator
20- Resource Administrator
40 - User Manager
100- Manager
300 -Application Editor
400 -Operator
700- Guest
800- Application Security Policy Editor
900- None
My remoterole Command is like below---
b remoterole role info admin '{
attribute "F5-LTM-User-Info-1=admin"
role administrator
user partition all
console enable
deny disable
line order 1
b remote role info guest '{
attribute "F5-LTM-User-Info-1=Guest"
role guest
user partition all
console enable
deny disable
line order 2
Thank you.
- Chris_Miller
Altostratus
I believe you're running into this:
http://support.f5.com/kb/en-us/solutions/public/10000/200/sol10272.html?sr=12690678
You can likely dump the users into bpsh or tmsh but not bash. A user will have to manually jump into bash per the steps above. - Shishir_84445
Hi Chris,
I saw the article and ask to use "!bin/bash" but its giving me following error
bp>!/bin/bash
BIGpipe parsing error:
012e0008:3: The requested command (!/bin/bash) is invalid
Any other idea?
Thanks. - Shishir_84445
Hi Chris,
I checked with other LTM and the Command is working, I think the specific LTM is having some problem. Thanks for your help.
