Dilip_bhapkar06's avatar
Dilip_bhapkar06
Jul 30, 2009
Urgent Help [Login into F5 issue]
Hi Friend,
I am in trouble. Bymistake i restore the old archive file.so now i am unable to login in F5 (console as well as GUI)
what should i do. Please help me,. as we have one more F5 standby so i did it as active.
I also tried to sync both its not sucessful.
I don't know the admin password of F5.
it gives error.
Kindly help me.
  • hoolio's avatar
    hoolio
    Try searching on AskF5.com for your version for 'root password reset'. You'll need to boot into single user mode and then reset the password using passwd. You can also find a solution on resetting the admin password there too.
    Aaron
