Stephan_Jaeger_
Apr 03, 2006Unchunk HTTP Request Body
im searching for a way to unchunk a http request body before sending it to the webserver which is unable to handle chunked reuqests. As both clients and servers are Appliances there is no way to configure either one for this situation and i want to avoid setting up an extra apache as reverse proxy.
Does anyone know a way to to this with iRules? Afaik our BigIP 6400 supports unchunking (at least in the GUI) only for the HTTP Response.
Regards
Stephan Jaeger
- hoolio
From other posts on the site, I think this should do it for requests:
don't allow data to be chunked
if { [HTTP::version] eq "1.1" } {
if { [HTTP::header is_keepalive] } {
HTTP::header replace "Connection" "Keep-Alive"
HTTP::version "1.0"
} - Stephan_Jaeger_
Posted By hoolio on 4/03/2006 4:07 AM
HTTP::version "1.0"
Thanks for your reply. I already saw that post but i'm not sure if that will work.
As i understand it this will change the request header to HTTP/1.0 so the server will send an HTTP/1.0 response. But what if this first request is an HTTP/1.1 POST with a chunked body? Just changing the protocol header won't fix anything, will it?
I think the code you posted is from here:
http://devcentral.f5.com/Default.aspx?tabid=29&articleType=ArticleView&articleId=25
The description there says We also modify the request HTTP version to ensure that the response is not chunked.
But my problem is that the request body needs to be unchunked, not (only) the response.
Sadly i don't have the client appliance here right now so i have to wait until i can test this. - IheartF5_45022
Nacreous
This works;-
http://devcentral.f5.com/wiki/iRules.HTTP%20Request%20Unchunker.ashx
Joanna
