UDP Traffic not switched
i have Pool with 2 Members & Priority Group activation One Pool member is Primary & Second Pool member receives traffic only if First pool member is down ( using priority Group activation ) Issue is , when Primary pool is down ... not all traffic is switched , alot of requests still being sent to The primary pool member ( while its status is down by Monitor ) Any Clues ? Traffic is UDP Traffic
- R_Marc
Is it down by monitor or marked down manually?
- Telnet-1_142114
By Monitor
- R_Marc
I suspect you are seeing monitoring traffic. I set up the following test:
Created a syslog-ng instance listening on two ports:
source s_net { udp(ip(10.0.0.194) port(514)); udp(ip(10.0.0.180) port(514)); };Created a virtual and pool pointing to it:
ltm virtual udp-test-vitual { destination 10.0.0.181:514 ip-protocol udp mask 255.255.255.255 pool udp-test profiles { udp { } } source 0.0.0.0/0 vs-index 11 } ltm pool udp-test { members { 10.0.0.180:514 { address 10.0.0.180 priority-group 100 session monitor-enabled state up } 10.0.0.194:514 { address 10.0.0.194 session monitor-enabled state up } } monitor udp }I set up some traffic pointing to it:
while [ 1 ]; do logger -n 10.0.0.181 -P 514 "testing"; sleep 1; doneI then disabled the .180 listener and saw:
15:41:26.391592 IP 10.0.0.20.57185 > 10.0.0.194.514: [|syslog] 15:41:26.989738 IP 10.0.0.194.51250 > 10.0.0.180.514: SYSLOG kernel.notice, length: 34 15:41:27.993237 IP 10.0.0.194.35184 > 10.0.0.180.514: SYSLOG kernel.notice, length: 34 15:41:28.995634 IP 10.0.0.194.56747 > 10.0.0.180.514: SYSLOG kernel.notice, length: 34 15:41:29.997998 IP 10.0.0.194.58083 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:30.398929 IP 10.0.0.20.52386 > 10.0.0.180.514: [|syslog] 15:41:31.002259 IP 10.0.0.194.51332 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:31.400153 IP 10.0.0.20.57185 > 10.0.0.194.514: [|syslog] 15:41:32.007825 IP 10.0.0.194.43167 > 10.0.0.180.514: SYSLOG kernel.notice, length: 34 15:41:33.010977 IP 10.0.0.194.50478 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:34.013450 IP 10.0.0.194.55872 > 10.0.0.180.514: SYSLOG kernel.notice, length: 34 15:41:35.015700 IP 10.0.0.194.47666 > 10.0.0.180.514: SYSLOG kernel.notice, length: 34 15:41:35.407133 IP 10.0.0.20.52386 > 10.0.0.180.514: [|syslog] 15:41:36.020327 IP 10.0.0.194.39738 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:36.407760 IP 10.0.0.20.57185 > 10.0.0.194.514: [|syslog] 15:41:37.023422 IP 10.0.0.194.41399 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:38.025852 IP 10.0.0.194.54688 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:39.030245 IP 10.0.0.194.44862 > 10.0.0.180.514: SYSLOG kernel.notice, length: 34 15:41:40.035572 IP 10.0.0.194.47855 > 10.0.0.180.514: SYSLOG kernel.notice, length: 34 15:41:40.412448 IP 10.0.0.20.52386 > 10.0.0.180.514: [|syslog] 15:41:41.038749 IP 10.0.0.194.33010 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:41.312193 IP 10.0.0.20.57185 > 10.0.0.194.514: [|syslog] 15:41:42.040993 IP 10.0.0.194.36688 > 10.0.0.180.514: SYSLOG kernel.notice, length: 34 15:41:43.045679 IP 10.0.0.194.40301 > 10.0.0.180.514: SYSLOG kernel.notice, length: 34 15:41:44.050950 IP 10.0.0.194.55865 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:45.054075 IP 10.0.0.194.40416 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:45.320777 IP 10.0.0.20.52386 > 10.0.0.180.514: [|syslog] ----- Disabled listener here -------------------------------------------------------- 15:41:46.056506 IP 10.0.0.194.37147 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:46.321038 IP 10.0.0.20.57185 > 10.0.0.194.514: [|syslog] 15:41:47.061121 IP 10.0.0.194.42987 > 10.0.0.180.514: SYSLOG kernel.notice, length: 34 15:41:48.066190 IP 10.0.0.194.49487 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:49.069365 IP 10.0.0.194.55249 > 10.0.0.180.514: SYSLOG kernel.notice, length: 34 15:41:50.071796 IP 10.0.0.194.45676 > 10.0.0.180.514: SYSLOG kernel.notice, length: 34 15:41:50.326123 IP 10.0.0.20.52386 > 10.0.0.180.514: [|syslog] 15:41:51.076485 IP 10.0.0.194.43712 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:51.326700 IP 10.0.0.20.57185 > 10.0.0.194.514: [|syslog] 15:41:52.079590 IP 10.0.0.194.44853 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:53.082110 IP 10.0.0.194.53688 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:54.084631 IP 10.0.0.194.53723 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:55.088803 IP 10.0.0.194.52233 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:55.331950 IP 10.0.0.20.55542 > 10.0.0.180.514: [|syslog] 15:41:56.094137 IP 10.0.0.194.43624 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34 15:41:56.333928 IP 10.0.0.20.57185 > 10.0.0.194.514: [|syslog] 15:41:57.097979 IP 10.0.0.194.46896 > 10.0.0.194.514: SYSLOG kernel.notice, length: 34Monitor traffic continued. Real traffic stopped.
