phoenix64's avatar
phoenix64
May 21, 2019
Two TCP connection into One
im looking towards some solution for following scenario :
we have a client to server connection which the connection will only establish on Strict Specific client Source Ip, and Strict ClientSource Port -to- Specifict Strict Server Destination Ip and Specifit Strict ServerDestination Port.
now , we wanna add one more Client و with restrictions above ( Strcit Source IP/Port -to- Strict Dest IP/Port)
how can i figure this out with F5 , in case of that Two Tcp Connection From Clients get Terminate in F5 and F5 Establish the TCP connection to The Server With The Restrictions that i`ve mentioned .
  • If not standard HTTP traffic, guessing it is not, then you are not likely to be able to do this without some complex iRule or iRuleLX solution.
