DV_25303's avatar
DV_25303
Nov 16, 2009
TWO ISA 2006 + NLB having problem to access BIG-IP LTM and Virtual Server
Hi there,
I'm having a problem with a structure of TWO ISA Servers 2006 + NLB and BIG-IP LTM.
My structure is like this:
Two Isa Server 2006 in NLB mode
Two BIG-IP LTM
All them are in the same subnet, like: 10.1.0.0/16
The problem happen when some machine behind of ISA Server (using ISA Server as default proxy) try to access the big-ip or try to access some virtual server behind BIG-IP. All attempt are unsuccessful.
Inner the BIG-IP, when I do a ping, the response is:
ltm02:Active] ~ ping 10.1.1.25
PING 10.1.1.25 (10.1.1.25) 56(84) bytes of data.
64 bytes from 10.1.1.25: icmp_seq=0 ttl=128 time=1.46 ms
64 bytes from 10.1.1.25: icmp_seq=0 ttl=128 time=1.47 ms (DUP!)
64 bytes from 10.1.1.25: icmp_seq=1 ttl=128 time=0.573 ms
64 bytes from 10.1.1.25: icmp_seq=1 ttl=128 time=0.574 ms (DUP!)
Does anyone know what could be happening?
I just posted the same issue in MS forums and all guys doesn't know what is happening.
Thanks in advance.
David
  • Hi,
    The ping DUP (duplicate) is the NLB cluster configurated in unicast mode.
    So, the two server NLB have the same mac address (like 02-BF-...) and generate the brodcast traffic.
    The problem, with the access to the virtual server from NLB proxy, is probably the conf of BIG-IP with auto_lasthop.
    I have never tried these solutions, but there are these articles about this situation :
    http://support.f5.com/kb/en-us/solutions/public/1000/500/sol1564.html
    http://support.microsoft.com/kb/317239/en-us
    In my NLB configuration, there were two ethernet cards, and i have configurated the second card with a new IP in the same subnet/class,
    and I have added a static route to the IP of virtual server from this second card with no NLB flag.
