DWiggins_116310's avatar
DWiggins_116310
Dec 09, 2013
Trouble with a remote logging iRule
So this should be a very simple iRule but I'm stumped. The purpose of this iRule was to log on a remote syslog server the external IP of any clients that connect to a specific Virtual Server. I've reviewed a number of other threads and I look to have the rule right but when its enabled on a VS it the site just goes to a connection reset error message.
when CLIENT_ACCEPTED {
log 10.33.116.27:5514 local0.info "Client Connected, IP: [IP::client_addr] to XXXXX"
Thanks for any thoughts you can provide.
  • Richard__Harlan's avatar
    Richard__Harlan
    Historic F5 Account
    a better way to do this is the following
        set hsl [HSL::open -proto UDP -pool ]
         HSL::send $hsl "Client Connected, IP: [IP::client_addr] to XXXXX"
    • DWiggins_116310's avatar
      DWiggins_116310
      I gave this a chance since the other option I had was less desirable. I setup the HSL options and pool and then added this iRule. I show logs of the F5 of the rule being successfully applied. That said I'm not seeing anything new coming into the syslog server. I'll poke at it for a little while and see if I can get it to work. As a side note, this site won't be accessed on a huge scale so in-line processing to a remote log server is completely acceptable. If I can get the syntax right would also work.
      Richard__Harlan
      Historic F5 Account
      If you want true remote syslog then follow this http://support.f5.com/kb/en-us/solutions/public/13000/000/sol13080.html
