Transparent and Blocking mode in the same ASM Policy?
Hi all,
My scenario is one ASM Policy (ASM-1) applied to one Virtual Server (VS-1). On the other side, I have a Local Traffic Policy which enables ASM-1 when the url starts with /application1 or /application2, otherwise disables asm. ASM-1 iw working in Blocking Mode.
It would be possible to add a new application (starting with /application3), which is in VS-1, but working in Transparent Mode? In my actual scenario, changing the policy ASM-1 to Blocking Mode would affect application1 and application2.
Thanks in advance.
You can assign multiple ASM policies on the same VS by using Local Traffic Policies.
Just pay attention to the strategy adopted : best-match, all-match, first-match
If you have to protect /application1 and /application1/test using 2 different ASM policies, you need to define 2 rules. In this case, the first rule must assign the ASM policy for /application1/test and first-match strategy should be adopted.
- Albert_252822
Hi Yann, this was my first idea, but in each rule I define a different ASM Policy (one Transparent and the other one in Blocking Mode) and ASM only allows to have one active policy for each Virtual Server. Having an ASM Policy without a VS associated, it won't work because of next: "A security policy not associated with a virtual server is unusable because no traffic will go through this security policy, and therefore it is meaningless to run the Policy Builder on this type of security policy."
- Yann_Desmarest_
Nacreous
- Albert_252822
