ahmede_193999
Feb 22, 2017Topology Records - Topology Load Balancing
When Topology load balancing is used on BIG-IP DNS/GTM and the "Longest Match" option is selected (Default), the system will search all records and choose the one with the longest match. If "Longest match" option is not selected, the system will choose the first record.. So my question is, when will the record weight play a role in choosing the record?
- Michael_SlavinsRet. Employee
"Record weight" plays a role when of both LDNS and virtual are found, the weight of a topology record will be assigned to a virtual server.
