Tip: How to check for HTTP errors with SOAP::Lite
A question was posed to me as to how one would check for HTTP errors (500: Can't Connect; 401: Authentication Required; etc). If you make a call with the SOAP::Lite package a HTTP level error will cause the script to die.
What you need to do is use an eval block around your method calls. Here is a script of code illustrating one solution:
eval {
$soap_response = $soap->get_list();
If at this point $@ is not NULL, then the eval failed from an HTTP connection error.
Otherwise, when it's not null everything is OK.
if ( $@ )
@tokens = split /\s+/, $@;
if ( "401" eq $tokens[0] )
print "AUTH ERROR ($tokens[0]): '$@'\n";
else
print "OTHER HTTP ERROR ($tokens[0]): '$@'\n";
else
print "Connection OK, proceeding...\n";
&125
-Joe
