Timeout for TCP/SSL Collect
Is there any way to put a limit on the SSL::collect or TCP::collect actions? I can't seem to find a built in function to do this, and was curious if anyone had a good method to do this.
- nitass
Employee
i think TCP::collect does not need timeout because it will always be fired.
With TCP::collect, the event for processing the data (CLIENT_DATA or SERVER_DATA ) will fire without TCP::release being calledTCP::collect
https://devcentral.f5.com/wiki/iRules.TCP__collect.ashxfor SSL::collect, i think after command may be usable.
config [root@ve11a:Active:In Sync] config tmsh list ltm rule qux ltm rule qux { when CLIENTSSL_HANDSHAKE { log local0. "" set mon [\ after 100 { TCP::close }\ ] SSL::collect 1500 } when CLIENTSSL_DATA { log local0. "" } } client [root@centos1 ~] curl -d test=1234567890 -ik https://172.28.24.10 curl: (52) Empty reply from serverafter
https://devcentral.f5.com/wiki/iRules.after.ashx - Kevin_Stewart
Employee
Both TCP::collect and SSL::collect have packet length parameter options. Can you elaborate on what you're trying to do? Are you trying to perform some function if no data is collected over some period of time? I'd be cautious in the use of an explicit timing function like after. It's definitely useful here, but can have some implications of CPU utilization.
