THE-F5_253023's avatar
THE-F5_253023
Jan 11, 2017
The type standard not work for ipv6
I've question for the configure between type standard and performance l4 to ipv6.
The follow flow traffic on test below
Client[ipv6] ---->
F5[config virtual]
type=standard
src IP ::0.0.0.0/0
dst ip 0:0:0:0:0:0:0:0/0 Port 80
tcp profile=tcp
Automap=none
address translation=disable
port translation =disable
--------> pool [Router gateways]
------------> to
So I tried test call to the www. ,it can't to access
but I do to change that from standard to performance L4 and then tried to call . , it's work
but So I test config on ipv4 [config similar above ] type "VIP standard" call to . it's work
I'm not sure it has a something in configure is wrong ?
Thank for a lot
  • I am not sure what you are trying to achieve with the above setting. May be try and use ::/0 for any IPv6 address and see if that would work. I have utilized IPv6 on VS for load balancing and it has worked without issues. Depends on your code version too.
