Tamer_Ezzat_235's avatar
Tamer_Ezzat_235
Apr 02, 2018
The system detected a CSRF attack and the operation was aborted
Hi All,
I have an issue with ASM, when I am trying to access Application security I am keep getting the following error "This request was unauthorized. The system detected a CSRF attack and the operation was aborted. Click Here to continue working on the system."
and below log from /var/log/asm
Apr 2 14:44:41 slot1/bigip1 info httpd[28100]: The system detected a CSRF attack and the operation was aborted. Page: js_http_action_items.php Apr 2 14:47:18 slot1/bigip1 info httpd[28101]: The system detected a CSRF attack and the operation was aborted. Page: summary_overview.php Apr 2 14:47:18 slot1/bigip1 info httpd[28100]: The system detected a CSRF attack and the operation was aborted. Page: summary_overview.php Apr 2 14:47:18 slot1/bigip1 info httpd[31193]: The system detected a CSRF attack and the operation was aborted. Page: summary_overview.php Apr 2 14:47:18 slot1/bigip1 info httpd[31191]: The system detected a CSRF attack and the operation was aborted. Page: summary_overview.php Apr 2 14:47:18 slot1/bigip1 info httpd[28098]: The system detected a CSRF attack and the operation was aborted. Page: summary_overview.php Apr 2 14:47:23 slot1/bigip1 info httpd[28100]: The system detected a CSRF attack and the operation was aborted. Page: js_http_action_items.php Apr 2 14:47:46 slot1/bigip1 info httpd[31193]: The system detected a CSRF attack and the operation was aborted. Page: js_http_action_items.php Apr 2 14:47:51 slot1/bigip1 info httpd[31193]: The system detected a CSRF attack and the operation was aborted. Page: js_http_action_items.php Apr 2 14:47:58 slot1/bigip1 info httpd[31193]: The system detected a CSRF attack and the operation was aborted. Page: js_http_action_items.php Apr 2 14:50:37 slot1/bigip1 info httpd[28101]: The system detected a CSRF attack and the operation was aborted. Page: js_http_action_items.php Apr 2 14:50:41 slot1/bigip1 info httpd[28101]: The system detected a CSRF attack and the operation was aborted. Page: js_http_action_items.php Apr 2 14:50:44 slot1/bigip1 info httpd[28101]: The system detected a CSRF attack and the operation was aborted. Page: js_http_action_items.php Apr 2 14:51:23 slot1/bigip1 info httpd[31194]: The system detected a CSRF attack and the operation was aborted. Page: js_http_action_items.php Apr 2 14:51:29 slot1/bigip1 info httpd[31194]: The system detected a CSRF attack and the operation was aborted. Page: js_http_action_items.php Apr 2 14:51:36 slot1/bigip1 info httpd[31194]: The system detected a CSRF attack and the operation was aborted. Page: js_http_action_items.php
Please advise in this strange issue
Thanks in advance
  • Tikka_Nagi_1315's avatar
    Tikka_Nagi_1315
    Historic F5 Account
    Hi Tamer,
    Are you getting this error when accessing ASM directly or launching ASM configuration utility via enterprise manager? In the latter case, it is known bug with id 660049. In either case, I would recommend that you open a support case for this and provide asmqkview from the device.
    Thanks,
    Tikka
    • Goto_1973_36322's avatar
      Goto_1973_36322
      Hello, MAny thanks for your answers. Problem seems dur to explorer 8 on my windows 7. I installed firefox and the probleme gas disappreared. Regards
  • Hi
    I had the same Problem today. After a while I realized that my root partition was full. After cleaning up the root partition the CSRF message in ASM disappeared too.
    Simon
  • Hello, MAny thanks for your answers. Problem seems dur to explorer 8 on my windows 7. I installed firefox and the probleme gas disappreared. Regards
