nathe's avatar
nathe
Sep 13, 2010
test block script
Hi all,
We used to have a test block script which we could enter into a field on our corporate website and trigger a block response. This was a quick way of testing ASM was working. This script isn't working now. In the ASM logs it's now classed as a legal request.
Can anyone share a test block script I can use to test ASM is blocking correctly?
Thanks in advance,
N
  • Tom_Spector_50's avatar
    Tom_Spector_50
    Historic F5 Account
    Finding payload that triggers a block on your ASM is dependent on your configuration - for example if you are blocking on illegal file types, and do not have a wildcard file type - sending a request to a non defined file type would trigger a block.
    Thanks,
    Tom.
  • Hi Nathan, did you create scripts for testing different ASM policies? I just created some scripts to test the ASM policies (For example, XSS) to see if ASM can block the request, but I am not sure how the blocking response works? It will be great if you can share your experiences and I really appreciate it. Thanks!!
  • nathe's avatar
    nathe
    I just did similar to you really, I crafted my own (very simple) XSS attacks. As Tom mentioned below, it's very much determined by the configuration. We blocked certain meta-characters so simply using these in a input field caused a block.
  • Hi Nathan,
    I do usally test my ASM functionality with the "Nimda Worm" signature (aka. a IIS specific Escaped Character Decoding Command Execution Vulnerability).
    the Test-URI is rather handy and simple:
    http://www.example.com/scripts/..%255c../winnt/system32/cmd.exe?/c+dir
    Note: The string "/..%255c../" is the actual attack signature and would double decode on the serverside to "%5c" in the first round (security validated by IIS) and on the second round to "\" (not security validated by IIS).
    And the ASM response blocking functionality can be testet with an Error Page sending an unknown [HTTP::status] of lets say 666.
    Cheers, Kai
