Adrian_L_3242's avatar
Adrian_L_3242
Jul 26, 2009
TCP Port Monitor for NFS.
I have setup NFS LB. This basically requires you to create a pool with a wildcard and then virtual hosts on the ports you need. Problem is you can't put a TCP or UDP monitor on the NFS pool to check for member availability.
Can this be done with an iRule or perhaps a script monitor. If so how?
Thanks.
  • hoolio's avatar
    hoolio
    You shouldn't need a script monitor for this unless you want to do protocol level checking of the NFS server. You can configure a standard TCP and UDP monitor for a specific port and then associate it with the wildcard pool. You'll need to know each TCP and/or UDP port you want to monitor. This page has some detail for NFS (Click here).
    Aaron
  • Yes. Thankyou. I just added the port to the Alias in the TCP monitor and that worked.
    Regards.
