tcp monitor failure
LTM V11.5.1 hotfix 10 ; one pool only with one member,tcp monitor ; when server power off , tcp monitor still Ok ; If choose icmp monitor , pool is down. tmsh command "f5 telnet 10.8.8.54 80" is ok ,but the server power down ; F5 ping 10.8.8.54 not ok ,can you explain this ?
- Alex_104543
Cirrus
Hi, i believe you are using a custom tcp monitor? Can you show what are the monitor settings?
Did you try using the default tcp monitor?
- Henrik_Gyllkran
Are you sure that it is the server that are actually responding to the tcp connections, and not something that responds on behalf of the server? Is the BIG-IP directly attached to the subnet where the servers reside? In that case I would look at the MAC addresses to make sure that it is the correct device that responds.
