Mike_Rausch_628
Aug 14, 2007TCP Info Logging
I am trying to write an irule that will log the TCP info that is being sent to and from the server/client. What exactly does the TCP::collect command grab?
- Andy_Herrman_22
TCP::collect gets the raw bytes that are sent. The data collected will be available in the CLIENT_DATA event.
For example:when CLIENT_ACCEPTED { TCP::collect 16 } when CLIENT_DATA { For logging in other events set cli "[IP::client_addr]:[TCP::remote_port]" set dataVal [TCP::payload] binary scan $dataVal H16 hexRep log local0. "TCP connection ($cli) sent: $hexRep" }
When the client connects this will cause (at least) 16 bytes to be collected. It then converts that data to a hex representation and logs it.
