AndyC_86542's avatar
AndyC_86542
Oct 10, 2008
Syntax help needed (very basic)
I want to assign the result of a comparison to a local variable. I keep getting "Invalid command name". This is the minimum code to show the problem:
 set param "wibble"
 set result [[HTTP::uri] contains $param]
Any ideas what I am missing.
  • hoolio's avatar
    hoolio
    Hi there,
    The []'s execute the code within. They're like backticks (`) in *nix. You can use 'expr' (Click here) or 'if' instead:
    set result [expr {[HTTP::uri] contains $param}]
    or
     if {[HTTP::uri] contains $param}{
        set result 1
        set result 0
    Aaron
