jato_40959's avatar
jato_40959
Nov 29, 2010
Sync Problem
Hello all,
I would like to push my config from the active to the passive box.
When performing a sync from the gui or from the cli, I get the following message:
Operation Status
Configsync Mode: Push
Transferring UCS to peer...
Installing UCS on peer...
OperationFailed exception:
Primary error : 16908289
Secondary error: 0
Error text : Error trying to determine whether configuration is encrypted or not.
Obtaining results of remote configuration installation...
Secondary error: 0
Error text : Error opening file for read operations
Error obtaining results of remote configuration installation.
Error installing UCS on peer.
Checking configuration on local system and peer system...
Peer's IP address: 10.99.99.2
Synchronizing Master Keys...
Saving active configuration...
Transport and install failed
Error running config sync all.
BIGpipe parsing error:
01110001:3: Error running config sync all
Any idea, please?
Thanx and regards,
Jose
  • hoolio's avatar
    hoolio
    Hi Jose,
    This error seems to be related to a read only mount. If you save a UCS from the active unit, manually copy it using scp or WinSCP to the standby unit and manually load it with 'b config install /path/to/file.ucs' do you see a more verbose error?
    Aaron
  • would u mind trying to restart httpd and do configsync again?
    bigstart restart httpd
  • Finally, the problem is an issue with the harddrive firmware. I nedd update the firmware through EUD.
    The disk partitions are in read only and the syn can´t write temporal files.
    mkdir: cannot create directory `/var/tmp/cert_temp': Read-only file system
    /tmp/cs_save_pre_script: line 41: cd: /var/tmp/cert_temp: No such file or directory
    /tmp/cs_save_pre_script: line 48: cd: /var/tmp/cert_temp: No such file or directory
    /tmp/cs_save_pre_script: line 63: cd: /var/tmp/cert_temp: No such file or directory
    mkdir: cannot create directory `/var/tmp/gtm_tmp': Read-only file system
    /tmp/cs_save_pre_script: line 84: cd: /var/tmp/gtm_tmp/gtm: No such file or directory
    tar: wideip.conf.sample: file changed as we read it
    /tmp/cs_save_pre_script: line 87: cd: /var/tmp/gtm_tmp/gtm: No such file or directory
    /tmp/cs_save_pre_script: line 95: cd: /var/tmp/gtm_tmp/big3d: No such file or directory
    mkdir: cannot create directory `/var/tmp/em_db_temp': Read-only file system
    Error creating package
    Error backing up current configuration.
    touch: cannot touch `/var/log/im.log': Read-only file system
    Fatal: executing: touch /var/log/im.log
    Operation aborted.
    /tmp/configsync.spec: Error installing package
    Config install aborted.
    01110001:3: Error running config install
    30/11/10 16:26
    I could see this problem, when i tried to do the manually copy.
    Thank you so much for all!!!!
    Operation aborted.
    30/11/10 16:26
