switch -glob (or -regexp) for multiple directories
I have some URLs that I want to match in a switch statement and I'm having trouble matching those cases where multple slashes appear before the uri name. For example:
- /uri
- //uri
- ////uri
- /completely/valid/uri
My existing switch -glob used a pattern like this: */uri*
This turned out to be way too liberal in that even though it matched the first three entries in my list, it would also match the fourth, which I do not want. The fourth item is a completely valid application path that just so happens to have a directory name that is the same as the entry I want to restrict at a higher level.
I'm wondering if there is a glob I should be using that will match what I am looking to match or if I need to consider using switch -regexp instead. I've read that there are cpu concerns using -regexp, so it would be nice to not have to go there if I don't need to. If I do go the -regexp route, should an expression like "\B/+uri" work?
- nitass
Employee
sorry i may be lost but can't we just check double slash (//) or more?
e.g.[root@ve10:Active] config b rule myrule list rule myrule { when HTTP_REQUEST { switch -glob [HTTP::path] { "/uri" - "//*" { log local0. "[HTTP::path] is rejected"; reject } default { log local0. "[HTTP::path] is allowed" } } } } [root@ve10:Active] config cat /var/log/ltm Mar 23 07:06:24 local/tmm info tmm[4950]: Rule myrule : / is allowed Mar 23 07:06:27 local/tmm info tmm[4950]: Rule myrule : /uri is rejected Mar 23 07:06:29 local/tmm info tmm[4950]: Rule myrule : //uri is rejected Mar 23 07:06:33 local/tmm info tmm[4950]: Rule myrule : ///uri is rejected Mar 23 07:06:47 local/tmm info tmm[4950]: Rule myrule : /completely/valid/uri is allowed - mahnsc
Thanks for responding! This is helpful and looks like it would account for all cases except where some developers may inadvertently utilize double paths in their code, although I do recognize that it wasn't listed as one of the four items in the original post. I do have some sites I support where automatically generated URLs from the app server have double slashes in their paths. (i.e. //completely//valid//uri// would fail using a pattern of " //* ") As I said though, this is helpful...I just do not know if I can use it globally across all my sites.
Does anyone happen to have more experience on the cpu issues with switch -regexp? How bad is it? The regular expression " ^/+uri " seems to cover all my bases, although I have not yet tested all combinations.
