khumfleet
Feb 21, 2012Stuck...Simple iRule? Not sure...req for Help
We are trying to use our LTM to route medical imaging (also known as DICOM) traffic to from our clients to one of two medical imaging archives (also known as a PACS) at our headquarters.
A...
Hamish
Cirrocumulus
Feb 24, 2012Posted By nitass on 02/24/2012 12:14 AM
thanks Hamish!
for example, there is one pool with two members. how can we modify tcp payload sending to pool member based on pool member which is picked up?
if we divide one pool to two pools which each contains only one member, how can we distribute traffic to both pool members evenly?
One pool? Not sure i see where we'd doit with one pool (although no doubt iwe could, it would get more complicated than a default pool and an alternate).
One VS as above though.
H
