khumfleet
Feb 21, 2012Stuck...Simple iRule? Not sure...req for Help
We are trying to use our LTM to route medical imaging (also known as DICOM) traffic to from our clients to one of two medical imaging archives (also known as a PACS) at our headquarters.
A...
Hamish
Cirrocumulus
Feb 23, 2012Posted By nitass on 02/23/2012 06:57 AM
just wondering how we can modify tcp payload according to pool member which is selected. in case of HTTP, we have HTTP_REQUEST_SEND event but this is tcp.
And use one pool? Could do. Or implement the rewrite when the number of poolmembers in the default pool goes to 0 and then select the alternate pool.
Then the client wouldnt have to worry about a second host to open the connection to.
