shishir_sontakk's avatar
shishir_sontakk
Feb 01, 2019
Strip URI word between first two "/"
Hello, I am looking to see how to strip a word between first two "/" in URI?
Example:
I would like to strip "abc" and store in some variable which can be used for sending traffic to different pool. Any help/direction/suggestion is appreciated. Thank you.
  • I am not sure if I understood by output values. Let me explain more what I am trying to do.
    I want to extract word which is between first two "/" in URI and modify the "Host" in the header with extracted word.
    Example:
    Extract "abc" and use that in header Host as ";.
    This "abc" word will be dynamic for different apps so I was thinking to store in variable ( using set) but not sure how I can extract that word.
    Thank you.
  • You can use getfield to return a specific part of the URI like this:
    set var [getfield [HTTP::uri] "/" 2]
    This will return abc in your case
    Or if you want to strip out/modify specific parts if the URI, you can use the split command to return a list of elements like this:
    set elements [split [HTTP::uri] "/"]
    set e1 [lindex $elements 0]
    set e2 [lindex $elements 1]
    set e3 [lindex $elements 2]
    set e4 [lindex $elements 3]
    In your case e1 would be empty, e2 would be abc, e3 would be garbage, and e4 would be moregarbage
    If you have any more questions, I am sure I can help
