Stream::expression & case insenitivity
I am trying to create a bit of a badword list and as a test intend to use this iRule. It works fine but I'm struggling to add case insensitivity to the mix. I've tried wrapping [string tolower] round it with no success and have read I may need to use a regex but wonder if there is a better way.
Any suggestions much appreciated.
Thanks.
when HTTP_RESPONSE {
HTTP::header remove server
foreach header {Server Date X-Powered-By} {
while { [HTTP::header exists $header] } {
log local0. "Removing- $header: [HTTP::header value $header]"
HTTP::header remove $header
Disable the stream filter by default
STREAM::disable
Check if response type is text
if {[HTTP::header value Content-Type] contains "text"}{
Replace content in STREAM expression
STREAM::expression "@badword@*****@ @badword2@*****@ @badword3@*****@" ]
Enable the stream filter for this response only
STREAM::enable
- hoolio
Hi Darren,
Unfortunately, the stream filter is case sensitive and doesn't accept the (?i) notation to set the expression as case insensitive. As a workaround, you can use character classes to match both cases:
STREAM::expression "@[bB][aA][dD][wW][oO][rR][dD]@*****@"
I think it would be useful for there to be a "case sensitive" checkbox on the stream profile (or via an iRule flag). If you agree, could you open a case with F5 Support and ask for an enhancement? If you end up doing this, could you reply with the RFE ID so others can reference it?
Thanks, Aaron - Darren_21048
Thanks Aaron, that works nicely. I've raised an RFE request with F5, if I get an RFE ID. I'll post it. - hoolio
Thanks Darren. Please do post the RFE ID.
The RFE ID is C850367. Also for info, I had to make a slight amendment to the statement.
STREAM::expression {[^A-Za-z][bB][aA][dD][wW][oO][rR][dD]1[^A-Za-z]@ ***** @ @[^A-Za-z][bB][aA][dD][wW][oO][rR][dD]2[^A-Za-z]@ ***** @"}
I had to add the curly braces and have added [^A-Za-z] at the beginning and end to make sure it's just whole words I'm filtering. I hope that is of use.- ebeng_278441
Altocumulus
Any luck with the RFE? im also struggling at the moment with upper/lower case in the streams
