mnowina_63180's avatar
mnowina_63180
Jun 15, 2008
Stream Filter Question
I'm having a strange issue using a stream filter within an iRule. I have two LTM-1500s and using the same iRule on both LTMs gives different results. On one, the stream filter is applied as soon as the rule is triggered on the other the stream filter is applied the second time the rule is hit.
Are there any configuration options aside from STREAM::enable/disable that control when the stream filter is applied?
Thanks,
Matt
  • hoolio's avatar
    hoolio
    The stream filter should be applied as dictated in the iRule. Can you add logging to the rule to track when the rule is triggered? If you want help troubleshooting this, can you post the two configurations from the bigip.conf? Include the VIP object, the iRule and any customized profiles added to the VIP.
    Aaron
