Still problem from http to https.
I want to redirect trafic from http to https from a liferay server. The function CSS is not Redirected. Look the url from httpfox
http://liferay-test.mydomain.com/frq-theme/css/layout.css?browserId=ie&themeId=file_WAR_frqtheme&languageId=fr_FR&b=6101&t=1394143338000 I'm used a Stream function and a Redirection Irule If you have a solution, could you please send me the detailed solution ? I have this problem from many month and with the openssl problem, the liferay server was exposed to internet because the redirection doesn't work. I'm not able to use the F5 to all my servers.
- nathe
Cirrocumulus
Simon,
You may want to share your stream profile settings to get DC peeps to check it out. Other things are: are you terminating the SSL connection and/or is the response from the server compressed?
N
- Simon_07_150650
Simple.
- nathe
Cirrocumulus
Simon,
Try removing http from Source and https from target and instead typing the following in the target box:
@http://@https://@
See this sol for more details.
Hope it helps.
N
- Simon_07_150650
Always the problem. Do i need to put the Stream configuration on my http-Vserver and https-Vserver ? Or only on the http-Vserver ?
- nathe
Cirrocumulus
Just the https vs I would say
